"VISA Resource Not Found" in MAX, but recognized by Windows Device Manager
I have been trying to figure out why I'm getting an error in MAX where no VISA resources are being read. I've uninstalled/reinstalled/repaired NI VISA, NI 488.2, and NI Serial as well as repaired the entirety of the LabVIEW software and nothing has worked. These were the main solutions I found on other forums, but I tried others as well like trying to change VISA system settings (After Installing 3rd Party VISA Software NI VISA No Longer Works - National Instruments), which also did not work. I attached a picture of what MAX looks like - it is not reading any device I plug in, and only shows this error if I try to open VISA settings.
I have genuinely exhausted my resources at this point, so if anyone has experienced this and used a different solution please let me know! Thanks in advance!
(1,466 Views)
What device are you trying to discover?  What versions of NI-VISA, NI-488.2, and NI Serial do you have installed?
My only other thought is to try to reset the configuration data in MAX (Tools->Reset Configuration Data).  That will require a reboot.
GCentral
(1,430 Views)
I'm mainly trying to connect to an Arduino Uno (I've downloaded LINX but can't do anything with it until I can read the VISA resource so the COM port is recognizable) as well as a B+K 9801 AC power supply and a KORAD KA3305P DC power supply, but those are less important. I have the most recent versions of all drivers downloaded which NI shows to be correct for LabVIEW 2020. I've already tried the MAX reboot as well, so that's been debunked.
(1,415 Views)
