"The compilation tools are not installed"
I have LabVIEW version 12.0 and I'm having the same problem. Which version of xilinx should I install?
Thanks!
Message 21 of 23
(1,289 Views)
What hardware are you trying to program ?
The best option is to install both version of the FPGA compilation tool.
You need 10.1 and 13.4. A search in the driver section gives this:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/da/pg/1/sn/catnav:du/q/xilinx/
Message 22 of 23
(1,282 Views)
I am trying to compile to a PXI-7813R, which has conected 3 C-Series Expansion Modules with diferents IO Targets in each module.
Thanks!
Message 23 of 23
(1,265 Views)
