"Set IP Address.vi" crashes with Error 56 (timeout)
I use a CompactRIO-9014 controller with LabVIEW 8.5 on a Windows Vista laptop. The cRIO communicates with the laptop over a crossover cable. I am trying to do system replication using the "Set IP Address.vi" to assign an IP address to my cRIO. The MAC address supplied to the VI is gathered correctly from the "Find All Targets.vi". The hostname used for the cRIO is the name assigned to it in Measurement and Automation Explorer. I downloaded the "Set IP Address.vi" from the LabVIEW Real-Time Module --System Replication Tools(Version 8.x), dated 08/17/2006. The same problem was located on www.ni.com > Search > Set IP Address.vi problems. There, a responder stated that the user should seek the most recent version of the System Replication Tools, and the problem should be therefore corrected. However, my 08/17/2006 version still has this error, and I cannot find a more recent version on www.ni.com.
A sample program that exercises this VI is attached as Replicate 04.vi.
Is there a user out there who has encountered this problem and found a solution?
Ben
(2,781 Views)
(2,764 Views)
