"Scan from string" function issue
Hi all,
I have a beginner's question. I am collecting some data from a micromanometer through labview. The input is through a serial RS232 port in ASCII format. Using one of the example VI viz, "Basic serial read and wirte" I see the data coming in the following way:
DP -0.123mmH2O
What I would like to do is now sort out the above string into just its numeric part and save it as a text file or table for post processing. I tried using the scan from string function but the final output i get is mmH2O if i scan it twice. Can please anyone help me find a solution.
Thanks for reading the post!
Message 1 of 8
(6,984 Views)
Have you tried the functions match pattern or match regular expression?
Check in context help and LV help about these functions.
These will help you to solve your problem.
Message 2 of 8
(6,983 Views)
Regular expressions are difficult (but not too difficult to make their value worth the effort); here's a reference I always use.
\- searches for the negative sign
{0,1} says to take it if you find it, but don't worry if it's not there (find zero or one of them)
[0-9] is a character class that will return a number
* says to take all that you find
\. looks for the decimal point
Jim
Message 3 of 8
(6,954 Views)
Hi ukbaisdumb
If the format of the string will be same  DP -0.123mmH2O then you can use the following method
regards,
shrek
Message 4 of 8
(6,951 Views)
Thanks guys! I should have mentioned I am using labview 7.1 and I do not have the regular expression function, so what do I do? I have the "match pattern" function and "scan from string" function.
Message 5 of 8
(6,905 Views)
Hi ukbaisdumb,
use ScanFromString this way:
It's as simple as it looks like... Search the context help for the different format codes!
In case the "DP" in front of the number can change: split the string at the " " (space) and scan for "%f"...
Message Edited by GerdW on 11-12-2009 09:56 AM
Message 6 of 8
(6,901 Views)
Incase if you need the units too...
Message 7 of 8
(6,895 Views)
Further to the problem, now I am reading the string from a VISA read block gathering input from a serial port, which is connected to a pressure measuring instrument. I have used the idea given in the example file of "basic serial read and write.vi" to read the input. Any suggestions as to how I should be doing this?
Thanks.
Message 8 of 8
(6,796 Views)
