call other exe in labview
Hi all
how to call an exe created in vc++ in labview...
(3,161 Views)
If it is an exe which can be run through command line, then you can use "System Exec.vi" irrespective of which language was used to create the exe.
(3,158 Views)
You can use system Exec function from Connectivity-->Libraries and Executables Palette. You can call your exe, the same way you invoke it from command prompt.
(3,157 Views)
