"IMAQ ArrayToColorImage" missing
I am trying to get Images from a USB-Camera and I found the driver in ni.com, I did not have Vision so I try downloading it from NI. I installed it and download some examples, but in every example it asks me for some missing files: "IMAQ ArrayToColorImage.vi", "IMAQ ArrayToImage.vi", "IMAQ Threshold".. Where are they? I installed Vision Acc. 8.2.3, but the driver usb_installer_setup.exe keeps telling me I do not have Vision. Thanks for the help.
(4,495 Views)
The files are part of NI VISION.  This is not included with LabVIEW and is an additional software package.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(4,486 Views)
Thanks. Problem solved, I installed the development module and got all the files. And as I understand if I make an .exe to be run in another system I need for each system a license from the vision run-time engine, right? Would it work for windows.ce? The .exe I mean. I want to run the app. in a small system (embedded controller). Thank you again for the help.
(4,477 Views)
Yes, you need vision license.  Not sure about CE.  They do have vision for their Compact Vision system that is a Realtime OS so maybe possiable.
Matthew Fitzsimons
(4,466 Views)
I do have the NI Vision package but in that package i donot have the Color.llb, library manager which contains the VI IMAQ ArrayToColorImage vi. Can you please tell me where I can download this VI from?
Roshni
(3,496 Views)
