"Get Key Names.vi" reads comment lines too?
It seems, that the vi "Get Key Names.vi" reads comment lines of ini-file too. (Comment lines begin with ";" or "#".) Is it bug or a feature or something I do wrong?
"Get Key Names.vi" has to read all keys of a specified section. But a comment is not a key!
Message 1 of 12
(5,087 Views)
Hi bohm,
afaik this is not a bug. You have to filter this lines if you need.
Mike
Message 2 of 12
(5,072 Views)
Yes, I did it.
In my opinion it's a bug. The programers simply overlooked comments in ini-files.
Message 3 of 12
(5,055 Views)
It's a bug. Comments should not be returned. If you use the Windows API function, comments are not returned. So says Microsoft, so says the world. Smiley Very Happy
Message 4 of 12
(5,053 Views)
This problem has been already reported to R&D (#93725) for further investigation.  Thank you for the feedback.
Balazs T.
Message 5 of 12
(5,005 Views)
What Windows API call are you referencing?
George M
Message 6 of 12
(4,991 Views)
You can use either GetPrivateProfileSection or GetProfileSection (for the win.ini file). Although these functions return the key-value pairs, comments are not returned. See attached example.
Message 7 of 12
(4,974 Views)
I am working with a config file right now and have done so in the past.  I have to avoid putting comments in the ini file although I would like to.  I will be thankful when this bug (or feature) is fixed.  For the time being, I put my comments in the vi that creates the config file and in the vi that reads the file.
Another work around is to create a fake section and put comments on the next line.  Just ignore it when you read it in.  See the partial config file below:
[Comment]
This is a test comment.
[GPIB]
In the above, Comment is read as a section and the entire next line is read as a key with no value.  Just ignore any sections that are labled Comment.  It really doesn't cause any problems.
- tbob
Inventor of the WORM Global
Message 8 of 12
(4,921 Views)
There's also the (long-standing) bug that when the config VIs write out comments, the VIs append the text ="" at the end of the comment. I had reported this a long time ago, and it has never been fixed. At least as far as 8.2 is concerned. I have no idea if it's still in 8.5 because I don't have 8.5.
Message 9 of 12
(4,919 Views)
Wow!
The last time I looked (LV 7.1) updating an ini file wiped out all of the comments. You mean we are allowed to use comments?!
Ben
Message 10 of 12
(4,914 Views)
