query
In a case :"WRITE :K2 TO COM 4 AND READ"  where one sub vi present in attached file so i want to calculate time required to run this sub vi..thankss in advance
Message 11 of 17
(1,342 Views)
As I said, you cannot calculate the time, you need to measure it. Here is what you could do to measure the approximate subVI call duration in milliseconds.
(Also, you string should go into a shift register. No local variables needed.)
Message 12 of 17
(1,340 Views)
how i can measure time in microsecond??
thankss in advance
Message 13 of 17
(1,322 Views)
Use "high resolution relative seconds" instead of "tick count". Cand be found in the vi.lib/utilities folder. (details)
Message 14 of 17
(1,319 Views)
hii friendss ..
i can communicate with ADM module with some basic command but
how I  can read advantech module name (i.e 4024,4017 etc)by using MODbus commands,
thankss in advance..!!
Message 15 of 17
(1,286 Views)
I recommend to start a new thread.
Your last question seems completely unrelated to what has been discussed here, so appending to a thread already marked as solved is not useful.
(... and please use a descriptive title this time. Thanks!) 😄
Message 16 of 17
(1,278 Views)
Hii
 I have another query.....
how I can generate  direct sequence spread spectrum using Bpsk modulation by LABVIEW 2011
please give me a basic idea from where I can start....
 thanksss in advance...!!!
with warm regards...
Message 17 of 17
(1,265 Views)
