push button true and release
HI,
I need to create a push button which command (true)a case structure : In this case structure I have an "Analog 2D DBL NSamp NChannel" which is doing an acquisition according to Nb of samples : What I what is that after this acquisition is completed, the pushbutton should be set automatically to false ; Do someone has already done this ?,
Thanks for the help
P,
(2,670 Views)
May be the simplest thing is to change the mechanical behaviour on the button. Right-click on the control, then Mechanical action>Latch when released.
That should do the trick : When you press the button, it remains at True until read (means until the acquisition will be started in the case structure), and returns to false immediately after.
CC
Chilly Charly    (aka CC)
(2,669 Views)
Well, posting the same question twice is somewhat confusing... Means that you can get the same answer twice (not to say 3 times ;)) and be sure that the provided solution is really robust...
CC
(2,660 Views)
