pure virtual function call when bulding application
Hi folks!
I'm trying to build an installer in LV 8.5 which needs to include the LV as well as the Vision Runtime engine. Including just one of these engines in the installer works fine, but including both results in the following error during the build process:
R6025 - pure virtual function call (see pic attached)
Has anyone seen this yet and knows what to do???
Regards, David
btw: hitting the ok button results in a crash of LV and the project manager!
(3,464 Views)
Hi David,
This error is referenced in the National Instruments knowledgebase.
Runtime Error (R6025) When Using LabVIEW
Nick_CH
(3,449 Views)
Hi Nick,
thanks for your response. Unfortunatly I neither use FiledPoint nor do I have script blocking tool like norton AntiVirus active. So the error must be caused by something else??? Anyways, I will reinstall LV and hope that will help.
Regards, David
(3,442 Views)
I had an app that throws tht error when shutting down LV.
If I remeber correctly, closing I/O refs and getting rid of simulated devices did the trick.
Ben
(3,423 Views)
I don't really know how I got it to run, but proving new paths to the run time engines during the build process seemed to solve the issue.
David
(3,409 Views)
