pulsed waveform
Sorry, just a quick question:
I have written a code to generate a stair case, so the user enter the start-stop-step values.
What is a fast solution to make a zero step between each step of the stair case?
that is for example 0 - 0.2 - 0 - 0.4 - 0 - 0.6 etc....
sorry if the question is too trivial...thank you. G.
(2,724 Views)
Accepted by gould
One way which comes to mind it to use your step generator on odd numbered steps and insert the zero on the even numbered steps. Quotient and remainder and a case structure will do it.
Lynn
(2,712 Views)
yes, it works!! 🙂
thn you....G.
(2,702 Views)
