property
hello,
i want to create objects dynamically. in the attechment there is a pic which shows the vi. there is also the pop-up menue which shows only four properties. is it possible to get the properties like position, color,... ?
best regards
markus
(2,966 Views)
Hi Markus
if you just use the code as shown in jpg (just the initialisation from you jpg)
you can achieve some results.You decide what properties to enable.
chow
xseadog
(2,926 Views)
Here are some vi's that may help you a little more. And just to let you that scripting is an undocumented feature and will probably not be of any use with the future release of LV8 at least this is what ni tells me. But I still like it and use it
Message Edited by jhoskins on 09-20-2005 09:32 AM
Joe.
"NOTHING IS EVER EASY"
(2,903 Views)
thanks for your posts. that's what need.
markus
(2,877 Views)
We work for stars. If you got the answer that you needed and it works then rate it.
Joe.
(2,869 Views)
