programming fuzzy logic controller design
please i am using fuzzy logic controller design. Inputs and outputs data are connected to an OPC server.
My question is: could i access programmatically (in the vi ) to the fuzzy logic controller design to prevent to enter in it each time that i need to change values ?
Samer,
(3,492 Views)
Hey,
If you are using the NI Fuzzy Logic VIs the controler parameters are stored in a file. In that case its not possible to access or change these programmatically.
Christian
(3,399 Views)
Hi
If I understood  your question correctly you want to change the fuzzy system properties in run time and I think it is feasible within the same subVI that you access to your fuzzy system.
There is an input to this subVI called "Controller data" it is actually a cluster which contain the properties of the system and you  can manipulate it before starting the fuzzification stage of your sysem.
I hope this will help.
Best regards
Afshin
(3,235 Views)
Hello all
The PID and Fuzzy Logic Toolkit 2009 was completely redesigned.
There are new API VIs and a more intuitive user interface for creating controllers.
You can create MIMO controllers with unlimited inputs and outputs, and also modify the controller on-the-fly.
Check it out the new features and let us know your needs on Fuzzy control.
LabVIEW PID and Fuzzy Logic Toolkit User Manual
Bruno Cesar
(3,060 Views)
