Having problem using Fuzzy Logic Controller
Hi to all,
I'm having alot of problems with the Fuzzy controller.
I cannot understand how to use the fuzzy controller in the labview. It looks like it is totally different from my understanding of fuzzy control.
Isn't there suppose to be a place where i can input my fuzzy control rules and also my so call input signal?
By the way, the system I'm trying to build is a fuzzy control SNP delivery system. The version of my labView is 8.5
Hope to get a reply soon.
Thank you.
(4,282 Views)
Yes, you can enter your rules in the Fuzzy Editor. To do that, you have to go to menu "Tools>>Control Design and Simulation>>Fuzzy Logic Controller Design".
After you created you rules and define the membership functions, you have to save the data to a file and, in your code, you have to use the "Load Fuzzy Controller.vi" to load into a LabVIEW diagram. This VI generates a cluster that you have to wire to Controller Data.
The input of the controller is called "in1". You have up to 4 inputs with this controler.
For more information, the Toolkit ships with a detailed manual that describes how Fuzzy works in LabVIEW, which we unfortunately call "PID_User_Manual.pdf".You can find in" C:\Program Files\National Instruments\LabVIEW 8.5\manuals".
Also, there are some examples that shows how to use Fuzzy in LabVIEW.
Hope this helps!
Barp - Control, Simulation, RTT and HIL - National Instruments
(4,269 Views)
Thanks for the reply. I'm now trying out with the Fuzzy controller. Thanks!!
(4,248 Views)
Hello all
The PID and Fuzzy Logic Toolkit 2009 was completely redesigned.
There are new API VIs and a more intuitive user interface for creating controllers.
You can create MIMO controllers with unlimited inputs and outputs, and also modify the controller on-the-fly.
Check it out the new features and let us know your needs on Fuzzy control.
LabVIEW PID and Fuzzy Logic Toolkit User Manual
Bruno Cesar
(4,014 Views)
