programmatically open two front panels of the the same v.i type
i would to know if it's possible to programmatically open two front panels of the the same v.i type but with the activity on one front panel not affecting the activity on the other front panel..for example like the way you would open two windows of a browser e.g chrome ....thank you
Message 1 of 11
(4,646 Views)
Accepted by alpony01
You want to open two instances of the same VI?  That's simple.  Just make the VI reentrant.
Message 2 of 11
(4,642 Views)
thanks but i dont understand the meaning of making a  v.i reentrant..could you please elaborate?
Message 3 of 11
(4,630 Views)
Here is an example VI I made a while ago.  Open Main.VI then click for a new window, or click and drag from the listbox.  It just relaunches a new instance of a reentrant VI.
Message 4 of 11
(4,617 Views)
You will also need to select the reentrancy options for the VI that you want to open multiple instances of.  See the attached pictures.  The shortcut for it is Ctrl-I.
Message 5 of 11
(4,613 Views)
While this is not directly related to your problem, I think you would benefit from taking the online tutorials.  The fact that you refer to vi's as v.i's leads me to believe your experience with LabVIEW is minimal.
Can someone post these links for the benefit of our OP?
Thanks!
Bill
CLD
(Mid-Level minion.)
Message 6 of 11
(4,605 Views)
These?
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
Message 7 of 11
(4,599 Views)
@crossrulz wrote:
These?
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Learning NI
Yep.  Those.  🙂
Bill
CLD
(Mid-Level minion.)
Message 8 of 11
(4,586 Views)
thank you all very much..I would like to ask just a few more questions:1)how would you pass values to and from the clone VIs seperately?2)Is there a way of having the clone VIs have different title names when you open them so as to be able to differentiate them
Message 9 of 11
(4,553 Views)
sorrry i have figured out how to do both by using property node and invoke node..
Message 10 of 11
(4,546 Views)
