programmatically open help
Is there a way to programmatically open a help file linked to a VI through the VI Properties under documentation? As if you have the context help over the icon on the front panel and you presses "Detailed Help". I know there is a VI Property Help->Help Path, and I could open it with the System Exec.vi, but it doesn't check if the file is already open. Any ideas?
Michael
(3,528 Views)
There is a pallete Dialog & User Interface>Help (not sure if you are
refering to that).
This pallete has a function "Control Help Window", "Get Help Window Status"
and "Control Online Help". The second one returns if the window is open or
not.
Wiebe.
(3,513 Views)
Perfect. The first two you refer to, "Control Help Window" and "Get Help Window Status" are specific to the Context Help window, but the third does exactly what I want; opens my compiled Help file (.chm), and if I use it again while the Help file is open, it just brings it to the front instead of opening a duplicate like System Exec. Thanks!
Michael
(3,496 Views)
