programmatically modify VIs properties
Hi all,
I was wondering if there is a way to programmatically modifiy the properties of a groupe of VI.
In fact, what I want to do is quite simple, I´ve just finished an application (of about 100 VIs) for a customer, and shipped an exe ; so now I´d like to modify the "VI revision history" settings for all the VIs (source code) so that from now on, I can easily keep track of all the modifications.
Any trick to do that ? Maybe with scripting ?
Epictetus
Antoine Chalons
(3,200 Views)
hi there
attached is a melt down simple vi that lets you manipulate a list of selected vis (vis have to be in memory).
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,192 Views)
Thanks chris, you´re a legend Smiley Very Happy !
Epictetus
Antoine Chalons
(3,185 Views)
Hi TiTou,
Is this, what you needed? because I understood it in the way to put one revision- comment programmatically to all VIs of a certain project or App. And I couldn't find a way to do this.
Greets, Dave
Greets, Dave
(3,174 Views)
Hi Dave,
The VI posted by Chris does what I what (it turns on the "prompt for comment when saved") which is slightly different from adding a comment to all the VIs 😉
In my case, I've sent the built app to my customer and the source will stay on my company's server, this is just to make sure that if for some reason somebody modify and save a source VI, a comment will be added 😉
Epictetus
Antoine Chalons
(3,170 Views)
