programmatically make current value default for just one control
I am looking for a way to store the current value of a control (just one, not all) as the new default value programmatically. For this, I can't use the invoke method 'Make current values default', since that saves all front panel control and indicator values. I found out that I cannot hook up a reference to a control to this invoke method.
Does anyone have an idea?
Joost
(3,264 Views)
one solution is to safe the default value into a file and read it out when
you like to set your control to default. Not very fine but works.
Niko
(3,263 Views)
Thanks for your posting.
That was indeed plan B. I was just hoping there was a fancier way.
Joost
(3,263 Views)
