programatically instancing SubVI inside of lvlibp
I have a project that utilizes a plugin architecture to load some VIs dynamically.  It does this through the use of a packed project library.
The plug-ins that get loaded are generated via VI scripting.  The plug-in makes a call to a SubVI.  I know how to create the SubVI through VI scripting by using the New VI Object node and wiring the path terminal to the VI I wish to instance...but now I need to make it point to the one that's inside the PPL, not the native one stored on the disk.
To be specific, the name of the VI is IP_wrapper and the name of the PPL is view_support_lib.lvlibp.  Picture opening up the block diagram...I can right-click and drop down IP_wrapper.vi, or I can right click and choose the lvlibp, then a new dialog opens up and I choose IP_wrapper from inside that PPL.  If I then hovered the mouse over each of these, one would show up as IP_wrapper.vi, the other would show up as view_support_lib.lvlibp:IP_wrapper.vi.
I know how to add IP_wrapper.vi to a block diagram via VI scripting, but what I am asking is, how do I add view_support_lib.lvlibp:IP_wrapper to a block diagram via VI scripting?
(2,732 Views)
Accepted by bmishoe
You might need to use the Get Exported File Path.vi, which is buried in the File I/O->Advanced File Functions->Packed Library palette.  That will give you the full path of the VI you are looking to add.
(2,727 Views)
I would agree with Crossrulz that you will likely need the get exported file path VIs, but Im not sure I understand what you are doing or why.. Why are you creating new VIs as your plugins? Why dont you just call the VIs using the open VI reference function?
(2,707 Views)
