programatically bypass or execute subVI
Hello
Is it possible to programmatically run or bypass a subVI? I have several subVIs in the main VI. Depending on which of them are selected using the front panel control booleans, I would like to run the selected SubVIs and bypass the rest of SubVIs. How can I achieve this? I have at least 8 of subVIs which can lead to several combinations, so I dont want to use the case structure for running the selected SubVIs.
Your help is highly appreciated,
Regards
Renju Zacharia
(2,874 Views)
You only need to deal with "combinations" if you use a single case satructur. Instead, put each one in its own case structure. 😉
(2,865 Views)
Sorry for the typos, posting via phone....
(2,864 Views)
