program wont end (while loop stop control)
I have a data acquisition set up to acquire data for 100 ms (rate=10000 S/s, samples= 1000) when the PFI line on my DAQ device recieves a digital trigger. The entire code is in a while loop with a control wired to the stopping condition. The timeout on my DAQ assistant is set to -1, because I want the program to wait for the user to send the trigger signal. When I press the stop control on the front panel, the program doesn't end. I believe this is because the DAQ assistant is waiting to acquire data indefinitely because the time out is set to -1. I need the program to end when that stop control is pressed.
Any suggestions?
Thankyou
Message 1 of 9
(4,335 Views)
Show us your code.
Message 2 of 9
(4,329 Views)
And of course you started with a DAQ assistant.  Go back and start with one of these http://www.ni.com/white-paper/14121/en/
Now you have a framework that does what you want and responds to the user.
"Should be" isn't "Is" -Jay
Message 3 of 9
(4,315 Views)
This isn't the exact program, but its the same problem.
Also, I have a rising trigger to start acquisition.
Message 4 of 9
(4,298 Views)
Put in a timeout and see what happens.  If you don't get your data, you just skip the checking of the data.  Loop until you get your stop condition.
Message 5 of 9
(4,291 Views)
If I set a timeout and hit the stop control, the program waits for the timeout that I set and returns an error (200284).
Message 6 of 9
(4,287 Views)
Is this a problem for you, or just a comment?
Message 7 of 9
(4,281 Views)
A problem. When I press stop, I want the program to end immediately. Instead, it waits for the timeout then displays an error message. How do I get it to end as soon as I press stop?
Message 8 of 9
(4,278 Views)
Then you need a more suiable archetecture.  Start from a Finite measurment project template.  Call DAQmx Control Task with Abort as the input to end your task immediatly.  The DAQ assistant is not going to work for you.
Message 9 of 9
(4,266 Views)
