processing the array elements
@crossrulz wrote:
... I used a feedback node instead of a shift register in the example below...
Just want to add that feedback nodes will be converted to shiftregisters anyway by DFIR since LV2009.
Christian
Message 21 of 42
(3,864 Views)
Hi everyone,
                   please help me to do with the arrays.I have  a big array of 225 elements.I want to take the first four array indices elements and reverse it and then want to take the next four elements and reverse it..like that I want to do with the entire 225 elements.This is for an encoding purpose.I tried but failed to achieve.
Please help me to do this.
Message 22 of 42
(3,846 Views)
Hi Josy,
I've attached this VI saved in 8.2.
Christian
Message 23 of 42
(3,839 Views)
Iam trying to achieve this.
Message 24 of 42
(3,838 Views)
Exactly this is what my VI does.
Christian
Message 25 of 42
(3,836 Views)
Thank you so much christian.Smiley Very Happy
Message 26 of 42
(3,831 Views)
     Iam trying to display the system date and time.The time has to display in hours,minutes,seconds and in milliseconds.Iam succeeded and the VI is attached.But Iam trying to convert the time in string format to number and want to display it in an array in which the first index shows the year and second index shows the month and like that I want to represent the entire time string in 8 different indices.Please help me to do that.
Message 27 of 42
(3,816 Views)
     I want to make a display like this.Can you please give me instructions for achieving this?
Message 28 of 42
(3,792 Views)
Scan From String is one of my favorite functions...
Message 29 of 42
(3,782 Views)
     How can we convert a byte array into its original form?Suppose one data is represented as 4 bytes in a byte array how can we reconverted it into one value.I tried some ways using 'flatten to string' but it is returning the values in a non readable form(ie: @^,.5%..).Anybody any suggestions?
Message 30 of 42
(3,760 Views)
