problems with reusing VIs with .NET controls
I have some hardware devices that use .NET for control.  I am only able to get them to work if I create a LabVIEW project and place the .NET .dll files in the same directory or a subdirectory of the project file.  However, I want to be able to use the instrument VIs in other projects.  If I try to add an instrument VI to the new project, the .NET container is on longer able to load the .NET control.
My file structure is like this:
top/
├── project 1 ├── project 2 └── instruments/ ├── instrument 1
├── instrument 2
Ultimately I want to be able to make instrument VIs that make use of .NET controls that I can re-use for other projects.  Up until now I have been managing projects by file structure and not using LabVIEW project files.
Thanks.
(2,727 Views)
Hi laserduo,
Usually all .NET related code is placed "somewhere" in the system, installed by a proper setup tool and managed by the OS.
I never placed those .NET dlls in the project folder…
Maybe this default way would help to make the .NET component available in all your projects?
(2,644 Views)
According to https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAm6SAG&l=en-CA, if they're in the Global Assembly Cache they will be found automatically.  I'll look into doing that manually.  The drivers I received (from Thorlabs) do not install to the GAC automatically.
(2,606 Views)
