09-27-2019 12:36 PM
I have some hardware devices that use .NET for control. I am only able to get them to work if I create a LabVIEW project and place the .NET .dll files in the same directory or a subdirectory of the project file. However, I want to be able to use the instrument VIs in other projects. If I try to add an instrument VI to the new project, the .NET container is on longer able to load the .NET control.
My file structure is like this:
top/
├── project 1 ├── project 2 └── instruments/ ├── instrument 1
├── instrument 2
Ultimately I want to be able to make instrument VIs that make use of .NET controls that I can re-use for other projects. Up until now I have been managing projects by file structure and not using LabVIEW project files.
Thanks.
09-29-2019 11:27 AM
Hi laserduo,
Usually all .NET related code is placed "somewhere" in the system, installed by a proper setup tool and managed by the OS.
I never placed those .NET dlls in the project folder…
Maybe this default way would help to make the .NET component available in all your projects?
10-03-2019 08:02 AM
According to https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAm6SAG&l=en-CA, if they're in the Global Assembly Cache they will be found automatically. I'll look into doing that manually. The drivers I received (from Thorlabs) do not install to the GAC automatically.
