problems in calling C++ dll
Hi, I built a dll in C++ to write data to a shared data segment, and it works well in Labview. Then I try to call the Dll in C++, it can be successfully built but will break in the end. I have been in this problem for almost a whole day and couldn't find the solution.
Below is the source files of my Dll and dynamically calling program.
Dll:
Calling program.
(3,813 Views)
So, now you want people to help you with C++ calling a C++ DLL problem here on a LabVIEW message board?
(3,810 Views)
Your Store subroutine indicates e is an array of 7 elements.
Your calling subroutine passes the address of the last element in the array (&e[7]).  Try &e[0].
George Zou
(3,797 Views)
thank you for your reply as I know the question is not very "Labview". I changed the array address like you said and the problem is still there. Attached is my calling program and dll, could you have a look at it for me please?
(3,785 Views)
For C/C++ issue, you would be better help in the LabWindows/CVI group:
http://forums.ni.com/t5/LabWindows-CVI/bd-p/180
George Zou
(3,728 Views)
Accepted by Xinghe.W
Problem solved.  The working dll for both C++ and Labview should be like this. The shared data segment should also be declared like funtion and with "extern "C"" ahead. In addition, Labview can only read pointers from dll.
(3,684 Views)
