problem with multiple axis in XY Graph
Hallo,
I am plotting different variables in the same plot with multiple axis. I have the following problem (see attachment)
the secondary y axis on the right hand side of the plot has a big space from it and one of the other secondary axis on the right falls on top of others. I have tried it in both labview 8.2 and 8.5 with the same results.
any ideas?
thank you in advance,
thodoros
(3,118 Views)
Accepted by theodoros
Try the following moves :
right click-> pop-up menu -> advanced -> Reset scale layout
Chilly Charly    (aka CC)
(3,091 Views)
Hallo,
this seems to have worked.I will test it thoroughly.Do you now what has caused the problem?
thanks a lot!
(3,074 Views)
kindly mark chilly poast as solution, as in future it may be beneficial for others
regards
(3,065 Views)
21232 a écrit:
this seems to have worked. Do you now what has caused the problem?
First thing to check : was your graph pixel size a multiple of 13 ? did you cross the path of a black cat ? Any broken mirror wire around ?
Actually I have no clue of the problem source. What I know from experience (my first bug report) is that sometimes, LV graphs get corrupted, and a while ago (LV 7.x ?) this restore command was added to take care of the problem.
(3,046 Views)
