Showing results forĀ
Search instead forĀ
Did you mean:Ā
problem with html saving
Hello everybody
I try to print in a html file my diagram block, but after follow all the steps of the print menu when I push the save bottom I recieve the following message:
Failure saving file xxxx.html!
I think that this problem can be because the block diagram is big and the program can“t generate the pictures but I“m not sure.
Thanks for your time
(2,867 Views)
It's working here with LV 7.1.1 and Windows XP and a very big block diagram.
Can you post your vi, I'll check if it woks too.
Paulo
(2,861 Views)
I have printed the html pages. The problem was that I use LV7.0 and W98. I change it to LV7.1 an WXP and now I can print.
Goobye
(2,842 Views)
