取消
显示结果
搜索替代
您的意思是:
problem with get waveform history data
已解决!
转到解答
Hi, everyone:
I am using SIT to create a user interface in Labview to communicate with a simulink model. After I configure the SIT connection manager and run the vi, the output was displayed in the waveform chart.
Now I want to get all the history data of the waveform chart. I tried to use the chart history property node to access all the historydat set. But  there is nothing displyed in the Y part in the waveform cluster front panel...
Can anyone give me a hand on what is the problem? or has anyone meet the same problem when using SIT.  I am really confussed...
I have attached the vi, but to run this vi, you need to have a corressponding simulink model and SIT, so I am very sorry that you cannot run it
And many many many thanks for this.
/Shangning
0 项奖励
1 条消息(共 3 条)
2,423 次查看
解答
已被主题作者 shangning007 接受
I just realize this data is a 2D array of waveform, which contains 2000*1 waveform, and each waveform data only contains 1 Y value.
0 项奖励
2 条消息(共 3 条)
2,415 次查看
Please post your code in 2011 version.
0 项奖励
3 条消息(共 3 条)
2,413 次查看
