ā09-05-2005 02:28 PM - edited ā09-05-2005 02:28 PM
Message Edited by Ray Farmer on 09-05-2005 08:31 PM
Message Edited by Ray Farmer on 09-05-2005 08:32 PM
Message Edited by Ray Farmer on 09-05-2005 08:33 PM
ā09-05-2005 02:52 PM
LabVIEW, C'est LabVIEW
ā09-05-2005 02:54 PM - edited ā09-05-2005 02:54 PM
Ray, everything is explained in the online help š
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses. :D:D:D
Message EditƩ par chilly charly le 09-05-2005 09:57 PM
ā09-05-2005 02:55 PM
The reason appears to be fairly simple - if the path is empty, the string is treated as the beginning of the path, and as such receives the š of the drive letters (like c:\), which does make sense.
As to whether this should be so or should LV detect the fact that the path is empty and use a default (let's say the root directory of the current drive), I don't know.
ā09-05-2005 02:58 PM
ā09-05-2005 03:06 PM
ā09-05-2005 03:10 PM
ā09-05-2005 03:11 PM
I was expecting my filename or my relative path.
If my base path is empty and my string is a relative path then I should see a relative path!!!!
Ray
ā09-05-2005 03:13 PM
ā09-05-2005 03:19 PM
