problem with REGEX !
Hi ,
I want to select the value after Fourth tabulation or third tabulation ...
I dont find the regular expression that I can use.
Example :
12:34:37.173	25.7	24.8	15.98	27.1	0.5	3.34	584.5	24.0	86.0	946.5	77.5
15.98
Thank you ,
(3,985 Views)
I would just use Spreadsheet String To Array to get an array of your strings.  You then just use Index Array to get the value you want.
(3,956 Views)
Accepted by Sarah_LAB
Agree, REGEX is not what you want to use! Use as crossrulz said Spreadsheet String To Array
But since you asked... Regular expression is almost a programming language in itself and can almost do anything it if given the time to figure it out.
Problem with REGEX.pngChange the {3} to {4} to get the 4th item.
BUT choose the correct tool for the task
Spreadsheet String To Array!
Omar
(3,945 Views)
thank youuuu .
(3,918 Views)
