Hi!
I have some problem with understanding of LV8.6 Web Service RESTful!
Here my question:
I read many themes about web service: http://zone.ni.com/devzone/cda/tut/p/id/7350 and other but this examle don't work! The data what get from VI don't show in the web interface! Why?
How data go from LabVIEW to this programm created on Adobe Flex?
Hello Max,
When you open up the example you must expand the Build Specifications section in the Project Explorer and:
1. Right Click the We Services and select Build
2. Then right click each of them again and select Deploy.
Then you can view the data in the webpages.
Let me know if you have tried this already or if you have other questions.
Anna K.
Hello Maximillon,
As mentioned in the tutorial, you have the option to display graphics, such as the example shows in Demo 2b - Web Based FcnGen UI which is a thin-client application developed using Adobe Flex. Another option is to display the data in XML format as in Demo 2a - XML Data that you are referring to. Below you can see the difference between the two.
Anna K.
Hello Max,
Could you attach a screenshot of the webpage? Wjhat browser do you use?
Anna K.
I alwawys use Firefox/Afteer your question che this in Opera and Safari.
Like said higher - nothing.
Please tell me maybe there some error or I'll do some thing wrong, but execute all on instructon.
Can you try it in Internet Explorer? Also, do you get "page cannot be displayed" or do you see the graph but no data?
Anna K.
