Showing results forĀ
Search instead forĀ
Did you mean:Ā
problem with DAQ assistant on LABVIEW.
I installed the evaluation DVD today and when I placed my DAQ assistant in the code, I had a screen telling me that my license was not okay.
But my DAQ license is original .....
Just normal situation ?
grts
Message 11 of 14
(2,468 Views)
does that mean I should remove DAQ 9.0.2 and install 9.2.3?
Message 12 of 14
(2,458 Views)
Only if you want to use daq with 2010
Message 13 of 14
(2,456 Views)
Accepted by topic author KDGREAT.
Here is a KnowledgeBase that shows the compatibility of LabVIEW with DAQmx. NI-DAQ and LabVIEW Version Compatibility (for Windows)
Since you have LabVIEW 2010, you will need at least 9.1.5, as Dennis Knutson mentioned, but I would suggest using DAQmx 9.2.3.
Message 14 of 14
(2,442 Views)
