problem using state machine with structure event (mouse clicking)
Yes, it is the case in this example. In practical, the position will be randomized.
Message 11 of 19
(1,594 Views)
Getting the properties of the picture using the Property Node allows them to be randomized, the positions and sizes wont be hardcoded.
Message 12 of 19
(1,590 Views)
Oh yes, thanks I have not thought proceeeding like that.
So with your idea of shift register I don' have to use the event structure. But in this architecture can I even though (for practical reasons) continue to use event structure once or it is not possible?
Message 13 of 19
(1,586 Views)
Hi
I don't have found in your zip an event structure??? I send you an example in which i used event, i think that you can use such a structure for your code for sure.
You have to add 2 conditions in the main while loop, each condition can control an event (moussse click, mousse position....)
Kamal
NIF
Message 14 of 19
(1,582 Views)
Thanks, Yes, my code contains several events structures  with mouse up  commands. If you look at sequence structure, you will see them.
You mean  that  I have to write it with shift registers ?
Message 15 of 19
(1,580 Views)
Hi
I think that it is possible with register.
Kamal
NIF
Message 16 of 19
(1,575 Views)
Okay, thanks, but I don't see how to handle events like mouse clicking without event structure? For clicks on picture indicator and on boolean control.
Message 17 of 19
(1,569 Views)
Do you know how do this, please? Thank you.
Message 18 of 19
(1,562 Views)
RIght, I would still use the event structure to obtain the mouse click coordinates.
Message 19 of 19
(1,556 Views)
