problem, timed loop, cRio system
I use a timed loop on a cRio (9014) target and i like to check the loop cycle time. I operate the system in scan interface mode, with an NI 9403 DIO Module. I use a timed loop with a shift register and a not in order to toggle the DIO0 output.
I monitor the output with an oscilloscope and it works for a loop cycle equal greater than 10 ms for some reason it doesn’t work for smaller time cycles. I would expect that I could control the loop in microsecond steps and so the DIO output too.
Labview 9.0.1 sp1
LoopTimingSource: 1 MHz Clock
Advanced Timing Attributes: deadline -1, timeout -1, offset 0, structure name l5...
processor assignment: mode automatic
action on late iterations: all checked
Does someone now what I am doing wrong?
Regards Thomas
(3,075 Views)
Accepted by topic author zerosun
The scan interface mode on the fpga is a fairly slow interface. If you want high speed I/O, you need to program the FPGA yourself. Even if you only pass through the FPGA I/O directly to the FPGA without any additional processing, it will be faster than the scan mode. Here is a link to a app note.
https://www.ni.com/en/support/documentation/supplemental/08/understanding-ni-compactrio-scan-mode.ht...
(3,061 Views)
