problem on save an waveform
hellow!anyone can tell me how to save a waveform,i try to use "write file.vi"to save,but i can not get the file which has the following format:
1.0,2.0
1.1.2.5
what can i do to get such data format?thanks a lot!
(2,533 Views)
Hello �
I am afraid it was not very clear to me what you meant by 1.0, 2.0, 1.1.2.5 format. To save a waveform you can use the Write Waveforms to File.vi. If you want to save your waveform to a spreadsheet you can use the Export Waveforms to Spreadsheet File.vi which will convert your waveform to a text string and write the string to a file.
Hope this helps!
S Vences
(2,533 Views)
