problem in installing linx in labview 2016
I am facing problem in installing linx in labview 2016.
Message 1 of 8
(6,510 Views)
I'm sorry to hear that.
But sympathy is all you can get unless you are looking for help.  In which case providing some actual information in your message would be useful such as details as to what the problem is.  Are you getting any error messages?
Message 2 of 8
(6,479 Views)
You might also try posting on the LabVIEW Makerhub forums, they have a forum dedicated to LINX support.
=== Engineer Ambiguously ===
Message 3 of 8
(6,475 Views)
I likewise got several errors installing LINX recently. I fully updated all my labview versions and rebooted and then downloaded LINX through VIPM and it eventually worked. However, it probably took 4 times to get it to download and unpack properly. Also, just be aware that certain platforms are only supported on Labview 2014 32-bit apparently. Really sucks.
Message 4 of 8
(6,468 Views)
I am getting the below message while installing linx via VIPM.
Main Package Name: Digilent LINX (Control Arduino, Raspberry Pi, BeagleBone and more) v3.0.1.192
Package Name with Error: Digilent LINX (Control Arduino, Raspberry Pi, BeagleBone and more) v3.0.1.192
Error Message: VIPM could not install the package lvh_linx-3.0.1.192 .
Error Code: 5
Error Source:
Message 5 of 8
(6,456 Views)
Accepted by kashifsherwani
Error 5 is File Already Open.  Is it possible you have some anti-virus software that is scanning recently downloaded files (like the ones VIPM downloads) causing this issue?  Maybe disable them, and/or restart your computer?  I've never seen this error when installing a package.
Message 6 of 8
(6,424 Views)
Thanks it works after disabling the antivirus...
Message 7 of 8
(6,415 Views)
Error Code: 66
Error Source: Invoke Node in Set Control Value {Variant}__ogtk.vi->FF12E0D9886C633BB75A4AE817FFE51F->98866C41DF5F97DF23FCB101DB142055->F7C4E276637B8E633B6AFDD1EF2CE94A->OGPM Class.lvlib:9379CFD8CA331CF0E38A98FA9D7316C6->OGPM Class.lvlib:D5B6EB965D0BC09274E3E5144188318D->C816626B524CF3DD3AA4372A60C7FF8E->VIPM Main Window.vi
Can someone help me with error code 66 !
much appreciate!
Message 8 of 8
(3,580 Views)
