problem in generating an installer for a database connectivity project
What if my user want to see the database. You want me tell them to follow this procedure.
What I am doing may be not correct but my application needs exactly this only.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 31 of 35
(798 Views)
Hi dkfire,
             This(Program data) is quite new for me. Do you have any doc or link so that I can read it.
It will be great for me.
--Ranjeet
Message 32 of 35
(797 Views)
Message 33 of 35
(786 Views)
As I said before, if your user needs to change/view or have any other access to the file that your program uses/creates, then place the files in the users documents.
The installer can also do that!
And you can use the "Get System Directory.vi" to get the path to the users document folder.
What happens if the user delete your mdb file?
Do your program create a new one?
Message 34 of 35
(776 Views)
Why user will delete the mdb ?
What if user formatted his computer then If I store the exe file in d drive then I am in safe side, just saying other advantages.
Give me some doc if you have in this topic.
--Ranjeet
Message 35 of 35
(764 Views)
