When Trying to Install Labview 8.6.1 on Windows 7 Get Error Code -12
When Trying to Install Labview Deveopment Suite 8.6.1 on Windows 7 Get " *** Error: Windows SDK Function Returned an Error (Error Code -12)"
I assume a compatability issue will Labview installer and Windows 7.  Is there a work arround?
Message 1 of 22
(20,345 Views)
Since Windows 7 is not offially released it's highly doubtful that you will be able to get help from NI. I've been using Windows 7 RC and my LabVIEW 8.2 installation went though without any issues. Which Windows 7 do you have? Have you tried running the installed in XP compatibility mode? Are you installing into the default directory? Do you have any other NI software installed?
Message 2 of 22
(20,333 Views)
I figured as much, but maybe if enough peole are interested NI will be pushed to a solution.
It's not that the programm won't run, it's that the installer fails before it even gets installed.
I am using Windows 7 RC Build 7100.  It installs and runs just fine in Virtual XP Mode on Virtual PC for windows 7 (http://www.microsoft.com/windows/virtual-pc/download.aspx) which I find works better than compatability mode.
Thanks for your help.
Message 3 of 22
(20,312 Views)
Windows 7 is not supported for NI products. I'm sure once it's released support will quickly follow.
Here's a KB on compatibility.
Jeff | LabVIEW Software Engineer
Message 4 of 22
(20,309 Views)
I had the same problemWhen trying to install 8.6.1 on Windows 7, Build 7100.
Error Windows SDK function returned an error. (Error code -12).
Message 5 of 22
(20,097 Views)
I got the same error message while installing labview from setup.exe.you can install labview 8.6 by going to the Distributions\LabVIEW 8.6\LabVIEW860 and install.
Now i have problem installing the drivers.Is there a way to install the drivers ?
Message 6 of 22
(20,062 Views)
Jeff,
Windows 7 is going to be officially released in a few months time, shortly after LV2009 release. Are we going to have to wait till next year before this new OS is "supported"?
Message 7 of 22
(20,047 Views)
That would be up to R&D. If it's not supported in LabVIEW 2009, it'll have to be some release after that. Sorry I can't be more helpful than that.
Just from scanning some other forum threads, it looks like it 'more or less' works. It's just not been tested with R&D because we don't have a final OS to test with. Chicken and egg thing and all that.
Message 8 of 22
(20,011 Views)
Well, Microsoft are getting everone to beta test Win7 to make sure it does work with all kinds of software. Surely NI do not wait until a new OS has been formally released before they start testing (I am sure they don't...).
I suppose its just that my laptop is in need of a spring clean and XP is getting a bit dated now (and there is no point moving to Vista now).
Neil
Message 9 of 22
(19,998 Views)
Now that the Windows 7 RTM has been available for a while, is there any update on how to get LV and Win7 to play nice together?
Matt
Message 10 of 22
(19,404 Views)
