problem feeding multiple analog physical channels into while loop
Hi
I am reading multiple analog physical channels through DAQ Assistant.
when I split the signal and feed the values to a time loop, they don't update to the current value?
Why is this a problem. The values cannot come out of the while loop. (used probe to check this). How do i achieve the task.
(2,686 Views)
I don't believe you've taken any LabVIEW tutorials.  I highly recommend you do.
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
You missed the concept of data flow.  Data only flows out of a structure or node when all the code inside of it is finished.  Your loop never finishes because it is an infinite while loop.  Also, the corollary is that a structure or can't begin execution until it has received all of its inputs.
(2,674 Views)
Accepted by siril01
I have solved the problem using QUEUE function.
Thank You.
(2,663 Views)
I'm every curious to see how you went from the code in your first post to using queues in a span of 1.5 hours.
Bill
CLD
(Mid-Level minion.)
(2,648 Views)
I just looked up some examples. Seems its pretty easy.
(2,609 Views)
