problem downloading web server
Hi.
I've trying to use  (WPT) Web Publishing Tool. My main VI is part of a proyect. These are the step that I do.
1.- Open my LVproject
2.- Tools>Options>Web Server: Configuration    Enable Web Server=True  root directory = C:\   HTTP port=Default Time out=Default
3.- Tools>Options>Web Server: Visibles VI  =*
4.- Tools>Options>Web Server: Browser access =*
5.- Tools>WPT  Viewing mode = Embedded
6.- Directory to save Web page = C:\
7.- Save to disk
8.- In the figure 1 I click connect button and Figure 2 appears. But the progress bar never changes and I`ve to close this window.
9.- If I try to open the Web Server using http://localhost/interfase_1404c.html, I see the same screen (figure 2) (using IE and Mozilla firefox)
I'm using LabVIEW 8.2.1, Windows XP.
What do I have to do?
Any sugestion for this problem?
Raymundo Cassani
(3,645 Views)
Is the computer hosting the webpage different from the one running the VI?  If so, I believe you have to have the web page on the same PC as the running VI.
(3,616 Views)
No, the running VI and the webpage are in the same PC. I verify the vi.ini and it references correctly the path of the webpage
Raymundo Cassani
(3,614 Views)
Hi Ray!
Have you solved your issue?
Maybe you can try using the web server directory by default and check if it works. Another thing might be a firewall or some windows security blocking the content. Im attaching a couple of demos that might be helpful to you. Hope this information helps.
Have a great day!! 🙂
Oswald Branford
(3,537 Views)
Thanks a lot.
I solved the problem. In my application I was using a buffer of 1MB aprox. I minized that and my problem disappear.
Raymundo Cassani
(3,531 Views)
Hi Ray,
I have the same problem as yours..I have done the same step you're done. But I still get the same error as yours. i am using labview 8.2 and windows 2000. Do you have any suggestion or idea how to solve my problem?..If I do the monitoring web publisihing, it working. But when come to embedded mode, the error appeared. I just test the web publishing with the simple program .please help me..
Thanks..
(3,494 Views)
