problem compiling a fpga program on windows 10
I'll start by saying I have not used LabVIEW in a professional setting. I've only taken a class on LabVIEW and have other programing background. I'm using a cRIO to control a NI 9505 for motor control for my new job. The Problem is when ever I try to compile it gets stuck in a random step of the process and never finishes. I think this is because I am using Windows 10.
I've let It run for over 15 hours and still I am not able to compile. No errors show up in the logs, it just gets stuck in the process(I've uploaded a picture of what happens when it get stuck). I don't have access to a local machine on my network with windows 7 nor do I have a cloud compile service active.
Does anyone know how to fix this? Is it even possible to compile on windows 10?
(3,744 Views)
Do you happen to know where I could find information to get my cloud compiler working? I currently have the 60 day cloud compiler trial active on my account, but I get this error(picture attached). I think my IT is blocking something. I just don't know what.
(3,720 Views)
Here: https://users.niwsc.com/compilecloud/#/
If you have an active SSP, you have it already.
ALE Consultants
(3,718 Views)
Accepted by topic author truby
I was able to compile on windows 10 by running LabVIEW, as well as, the compile worker in windows 7 compatibility mode. Hope this helps others.
(3,664 Views)
