print sub VI
Hi all,
Can anyone please show me an example to print a subVI without open the subVI's front panel?
I try to print a txt file, but failed, hope someone can help!
with regard
Jaxx
(3,620 Views)
Hi Jaxx
Simply open a VI reference to the vi and then call the Print VI To Printer method using an invoke node. I can attach an example if you would like.
Kurt Friday
www.sciware.com.au
(3,618 Views)
Hi Kurt,
I tried it that before... but that is not so simple of my subVI... inside my subVI I need to read data(*.txt file) ---> display to a waveform graph ---> print the waveform graph whitout "show the front panel out"....
is it possible?
with regard
Jaxx
Message Edited by @ on 04-16-2005 12:17 AM
(3,614 Views)
Configure the subVI properties as follows:
Go to "VI properties...print options" and check "Automatically print front panel every time VI completes execution".
In the calling VI, right click on the subVI and select "subVI node setup...". Make sure that no boxes are checked.
(3,605 Views)
Hi Jaxx
Sure, all you need to do is goto the VI Properties of the vi that you want to print, select Print Options and tick “Automatically Print Front Panel Every Time VI Completes Execution".
I’ve attached an example that demonstrates printing a subvi’s front panel when called. Uses LV 6.1
Hope this helps.
Kurt Friday
www.sciware.com.au
(3,607 Views)
Hi, Altenbach
Hi, Kurt
Thanks for you two'suggestion... it work very well....
And I got another question about printing... it at outside the forum. Hope you two can help 🙂
best regard
Jaxx
(3,584 Views)
