multiple plots from 2d array
I am trying to plot multiple plots on the same graph from a 2-d array so as to have different colors for each element pair. The array is a 2x7. I just can't seem to bundle it properly to break it up into seperate arrays to plot on the same graph. And I want to do this generically so that a 2x10 would be handled as well. Any ideas?
Message 1 of 8
(5,209 Views)
I figured out a way using a bundle and shift register. Man some of the little things can really slow you down.
Message 2 of 8
(5,202 Views)
Wire directly your 2D array to a waveform graph. If the data appear "reversed" (lines in place of columns...) insert a "Transpose 2D array" function (in the array subpalette)before the graph.
CC
Chilly Charly    (aka CC)
Message 3 of 8
(5,205 Views)
@chilly charly wrote:
...insert a "Transpose 2D array" function (in the array subpalette)before the graph...
...or simply right-click the Waveform Graph and choose "Transpose Array".
Have fun!
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 4 of 8
(5,188 Views)
Well my solution did not work out exactly right. I should have mensioned before, I need to plot on an x-y graph. Still looking for a solution. I need to plot elements 0,0;1,1;2,2.. as seperate graphs on the same graph.
Message Edited by labviewprogrammer on 04-14-2005 05:28 PM
Message 5 of 8
(5,180 Views)
An XY graph needs a 1D array where each element is a cluster that holds an X coord and a Y coord. If you use several arrays together, you get several plots.
Do you want to take each row (2 elements) as a point in the graph?
If so, how do you know which rows to use for each plot?
___________________
Try to take over the world!
Message 6 of 8
(5,170 Views)
@labviewprogrammer wrote:
...I need to plot elements 0,0;1,1;2,2.. as seperate graphs on the same graph...
Well, well... this can't be à 2x7 array ! Could you give an example ?
CC
Message 7 of 8
(5,166 Views)
Hi LabVIEWProgrammer,
Do you want to plot separate plots only consisting of one coordinate each - basically only points, not plots? In that case you will have to split your 2D-array into "x,y"-array pairs, bundle these and build the clusters into an array (please see the attached SeparateXY.vi).
Let me know if this is not what you want, thanks.
Have fun!
Thinkbot Solutions
Message 8 of 8
(5,148 Views)
