print easy text.vi doesnt work in executable
I have 3 target machines running labview 2012 on a PXIe8101controller.  In my statemachine the vi prints out a report using easy text report vi ( on report generation pallet) at the end of the test.  Its an executable vi on all 3 machines.  On 2 of the machines it works fine.  On the 3rd it hangs up when I'm logged in as a standard user.  If I log in as administrator it works fine.  The thing I noticed is that on the 2 machines it works on, the image is "factory..1.2.1f6"  (under control panel>systems).
On the test equipment that it only works in admin mode the factory image is 1.2.4.f1.  Also MAX is 5.3.1 on the one that runs fine and 5.5.0 f1 on the one that  it doesn't work on.  Anything I'm mssing?
Thanks.
(2,736 Views)
Accepted by topic author Clint_Eastwood1000
solved...
(2,720 Views)
Maybe you can enlighten us with your solution so others may benefit.  Unless it was just something silly.  Then just say it was something silly.
Myself, I'd probably go ahead and post it, even if it was silly little mistake.  At worst, it's a laugh on me - at best, someone else made the same boneheaded mistake I lived through and they don't have to walk in my footsteps.  😉
Bill
CLD
(Mid-Level minion.)
(2,701 Views)
