DAQ Assistent Express: All channels read the same value even if some have no signal source.
When I utilize the DAQ assistent express VI to read 8 channels, all 8 indicators will display the same value even if only one channel is physically receiving a signal.  The DAQ device is a USB 6341.  The
DAQ Asst Express is set up for differential.
The shied drains are connected to the ground connections for each signal connection on the 6341.
in short, if i give ch 0 a 5 VDC signal, why do all channels read 5 vdc as well?  (even though nothing is connected to them)
Thanks in advance for the help.
Erik
(2,588 Views)
Hi Erik,
it's a MUX-type DAQ card and so you will notice crosstalk between channels!
Put some pull-down resistors on those free floating channels…
(2,584 Views)
It's called ghosting and is expected. Search for options to remove/minimize.
(2,578 Views)
