pretty simple
If this isn't what you want then I give up.
Message 21 of 24
(820 Views)
Here's a quick modification (LV8.0), eliminating the event structure (we don't really need it) and matching the show/hide selector to the graph legend for a cleaner and more intuitive UI.
Message 22 of 24
(808 Views)
The case structure with 33,34,...40 needs to stay. It's important for the program.
Message 23 of 24
(794 Views)
Well, that makes no sense, as you have not explained what you're trying to do, and these seemingly arbitrary requirements make it difficult to understand what you're trying to accomplish and to be able to indicate how you should write simpler and more efficient code. Regardless, whatever it is that you're doing, we're surely not going to write the entire program for you. As I indicated before, just use a simple Add primitive to add 33 to the iteration count, instead of that formula node. It's quite trivial.
Message 24 of 24
(785 Views)
