averaging in the loop
Hi all.  I would like to average 2D arrays whilst running the measurement. I attachhed the VI below, in which i receive data from 2 instruments and plotting them into a XY graph with history. What i want to do is averaging graphs every 200th sampling and plot it.
to make it clear:
 i start the measurement and collect 200 x and y datas lets call sample 1
as running the loop another 200 x and y datas (201th-401th datas) called sample2
and average them  ((1th+201th)/2, (2th+ 202th)/2,... and plotting.
when i get the another 200 x,y  datas ( 402th-602th  datas) called sample 3, i want to average
those with previous ones ( 1th+201th+402th)/3, (2th+202th+403th)/3
and keep doing this process till i stop the measurment.
I am a bit confused how to start with algohrithm. any hellp is appreciated
thanks
(4,107 Views)
Slow down!
First of all, lets assume you specify a resource (which you aren't), are you getting the data you want in the atttached VI by reading the VISA resource as opposed to the reading the read buffer????
Richard
(4,088 Views)
yes , I have 2 visa resources ( Multimeters ).
(4,083 Views)
...and you are getting data from the multimeters the way the VI is wired?
Richard
(4,074 Views)
yes it works fine. isnt it correct?
(4,071 Views)
i didnt show the resource name wirings, which are thee gpib adresses
(4,069 Views)
The missing resource was one thing. I was more surprised at the fact that you wired the resource into the string>number function, so your data IS the resource. Interesting.
Anyway, sorry if it seems I hijacked your thread with an urelated question.
Attached is a VI (saved to 8.5) that will hopefully give you some ideas on how to build the three samples of 200. I didn't quite understand your averaging, so I guessed at it.
Richard
(4,016 Views)
