precise synchronization
Dear Friends,
      Now I am programming a DAQ system basically using a while loop. I used the "i" in the loop to count and the TDMS technique to record data(1D array). When I pressed the "stop" button, the number of data arrays were always one larger than the count. I guess when the count stopped, the one more data array were writen into the file, I don't know why? And how can the precise synchronization be realized ? Here I show a picture of framwork of the main VI ,maybe it help to understand what i mean. I am sorry that the source code cannot be issued.
   So ,please help me if you have any idea.
  Thank you
(3,417 Views)
i returns 0 on the 1st iteration
1 on the 2nd
2 on the 3rd... etc
So if i reads, say, 4 I would expect the loop to have executed 4+1=5 times, so 5 acquisitions.
(3,402 Views)
Ok, I forgot "i" starting from 0, a stupid mistake. Do you think the structure of  this program OK?
(3,377 Views)
Is the "count" being one less the only issue you saw with your program?
(3,361 Views)
Yes, I think so.
(3,330 Views)
