post processing the pulse signals
I want to do the following post processing for a digital square signal
 1) How to get the time interval between two consecutive rising edges of a digital square signal
 2) To provide an time selection option for user such that when a particular value of time is entered  the time interval values corresponding to that value should be stored in a array) (say 30 seconds then it should store all the time intervals for the 30 second duration)  and to plot each obtained time interval.
Can anyone explain a way to do this.
Thanks.
(2,764 Views)
For number 1, there is a VI in LV that will do pulse measurements. Do a search in the function palette.
I'm not clear what you mean in your point number 2.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,737 Views)
Sorry I think I didn’t explained point number2corrwectly but this is what I want to do
I want to have a box in the front panel such that the user can enter a value for example if the user enters 30seconds then all the time intervals (between two consecutive rising edges) obtained for every 30 seconds should be stored in a array and each time interval (obtained from two consecutive rising edges) should be plotted continuously.
Please let me know if it is still not clear.
(2,732 Views)
For point number1
I tried as shown in the image below but it is not showing the required (time interval)duration between two conescuitve rising edges of the pulses.
I need to get the duration(time interval) between two conescuitve rising edges of the pulses.
Can I know how to get this and store in an array.
(2,718 Views)
