position indoors
Does any one know how i can determine a  position indoors  it has to be within 1 cm accurate
you must see it like large room let say 50  x50 x 3 meters
how do i determine a certain postion
i want to calc where a certain item is
Message 1 of 10
(4,512 Views)
You need to provide more information than that.
Is this some kind of math question?  Or are you using some hardware to measure the location of an object?  If so, what hardware?
Message 2 of 10
(4,511 Views)
ok sorry
well i think we can manage the math  ,the question  is more wich hardware is possible to do,
outdoors this is not a problem only indoors we do not see   with   what kind of hardware ,and posible location with that hardware you could do that
its a open space and and you can not point somthing to that certain location it has to find it himselve ( the hardware i mean)
Message 3 of 10
(4,485 Views)
The first two things that come to mind are laser distancing devices, and ultrasound emiters and receivers.
 If you were to look around, I'm sure there would be laser devices with analog or digital communications
_____________________________
- Cheers, Ed
Message 4 of 10
(4,473 Views)
still that no option   see it  as a robot moving around and want to know its postion
how can he find his postion?
Message 5 of 10
(4,450 Views)
If you don't want to use a laser then you could set up some radio frequency transmitters in the corners of the room, and triangulate your position from these, with a receiver on your robot.
 If you know the size of the room you are using, then laser measuring would probably still be more accurate.
- Cheers, Ed
Message 6 of 10
(4,447 Views)
well room is about 50x50 meters
and how do you determine indoors with sound your postion?
personaly i have no idea    with all the reflections
can you give me a hint or formula do do this
Message 7 of 10
(4,440 Views)
Search the web for the DARPA Grand Challenge. Most of the winners were using a laser gizmo to do what you are asking (look for a white box mounted on top or front of vehicles). I wrote a driver for one of those some years ago. It uses a laser that spins and measures distance to the frist thing it encounters. I think it was a "Slick 50" but my memory is not to be trusted.
Ben
Message Edited by Ben on 10-13-2008 10:55 AM
Message 8 of 10
(4,434 Views)
sorry ben did look at at still have no idea  how to determine a position  indoors
Message 9 of 10
(4,407 Views)
